SOURCE: n73 sim card registration failed
hello sarah_fox,
Please Press [ *#0000# ]
and tell me whats appear
Thank you for using FixYa.
SOURCE: Nokia 6500 slide sim card registration problemit
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
SOURCE: sim card registration failed
Check that sim valid,
Check with another sim card if problem not shows sim card may complaint do as follows
Take the sim crd out and rub gently with a cotton cloth, and reinsert it.
Or take to service provider & ask him to give duplicate sim.
If problem with mobile try to dial *#7370#(Format),
Or take mobile to Nokia care(Problem might be network ic).
SOURCE: Hi Sir, i am haris
Sir you might want to charge your phone and try to use other SIM Card if SIM card registration failed error still occur maybe its time to buy a new one
