Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
The feed dog lever on the Babylock 5260 serger is located on the right side of the machine, near the front. It is a small lever that can be moved up or down to raise or lower the feed dogs. To raise the feed dogs, you will need to push the lever up. If you are having trouble locating the lever, you can consult the machine's manual or contact a Babylock dealer or repair technician for assistance.
Lowering feed dogs You can lower the feed dogs by moving the switch at the back of the free arm to the left. Move the switch to the right if you wish to raise the feed dogs. Note: The feed dogs will not raise immediately when the lever is switched. Turn the handwheel one full turn or start sewing to re-engage the feed dogs.
Try this url for the manual to help you along with any other problems. http://www.pfaff.com/
Are you talking about the presser foot lever? That lever raises and lowers the presser foot. If you are talking about the feed dogs, there is usually a lever to raise and lower the feed dogs. Consult your owner's manual.
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
Shift the drop-feed lever to the right to lower the feed dog.
Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
ABSOLUTELY! The XL models of embroidery machines are supposed to automatically lower when you put the embroidery unit on, but I have had an XL-400 and currently have an XL-550 and Quintet, and I have noticed on the latter two that the feed dogs have not always automatically lowered. Incidentally, to lower or raise the feed dogs, the lever (it's in the back) goes DOWN and OVER. If you are having problems getting it move, use a straight blade screwdriver and pop the little tip off--it's not necessary to operating the feed dogs.
Also incidentally, when you raise the feed dogs, you have to turn the hand wheel towards (ALWAYS towards you for anything) several times to get the feed dogs to actually pop up. You'll hear when it does that. They lower right away, though.
The feed dogs on that machine (and many others) do not go back up when you move the feed dog drop button to up; they return to the up (feeding) position after the machine makes a stitch or two. So if they won't come back up after you tinkered with them, you will now need to bring it in for servicing.
Probably it is the spring loaded cam on the lower shaft not moving as it is bound up. The feed drop lever pushes it to the left to lower the feed dogs, but it has to spring back on its own after you move the lever back.
If you can remove the lower free arm cover you may be able to work it loose. Do not use 3 in 1 oil as it is gummy. Better to get Lilly white sewing machine oil.
Hope that helps!
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
How do I lower or raise button hole lever?
How to lower or raise button hole lever
how to lower or raise lever
