SOURCE: my vizio P42 went "pop" black screen with sound, any ideas?
Your TV mainboard is damaged and need to be replaced, the price should be around $80-190 and you can do it yourself.
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted
due to a power failure or fluctuation. Here's how to determine which is which:
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
SOURCE: there was a pop sound to the baCK OF THE TV AND NO
Y Sustainer problem. However, normally they have to change both Y Sus and Z Sus boards at the same time. If you lucky than it's just a fuse on the Y sustainer blown (the chance is very rare) otherwise the IPM (Intelligence Power Module) on the Y/X sustainer board is short. more then likely if you can get the IPM off of the board you will see that the components are shot, that is the popping noise you heard. shopjimmy.com has these boards some are cheap some are not...good luck
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
