The turntable won't make sound on its own when connected to the USB port. There are probably some drivers on the CD packed with the table that you'll need to install, and then you'll need to select the device in the Windows sound control panel. You'll also need some software to record and edit your vinyl if you want to transfer your records to CD.
I'm not familiar with the brand of turntable you have, just the ION, but it probably came bundled with some application on a CD. The ION table comes with Audacity, as well as some trial versions of audio processing (click and pop filter, hiss remover, etc.). Audacity is free, open-source software you can
download here if you want it. It allows you to listen to and record your vinyl audio as wave files, then edit it, split tracks, add effects, and other fun things.
