Its a 20 volt max lithium ion 3.0ah
SOURCE: Unable to get to brushes on DeWalt DW959 drill type 1.
the brushes are made to slide into the side of the motor. gently pull up on them. Also I would recommend that you go to Dewaltservicenet.com and type in your model number for a parts explosion and part number for replacement brushes. Let me know
SOURCE: Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
SOURCE: 14.4v dewalt xr2 drill
Some cordless Dewalt drills do not have open motors allowing access to the brushes. However there are a few styles that do.
If you want to check, open your drill. Remove the screws from the housing. Then remove half of the housing. You can see the motor at the back of the tool. If there are vents at the back of the motor you may be able to see the brushes the removable type are connected to a gray or tan piece of plastic mounted at the back of the motor.
If the brushes are from a removable style you can purchase a brush set. If they are hidden in the motor. You will have to change the whole motor.
You can check the Dewalt Service Net web site to find out.
SOURCE: cant figure out how to remove brushes
go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and it will take you to a page so you can bring up a schematic on this tool. let me know if you need any more help
SOURCE: I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
