Hi, I have just installed Windows 7 64-bit and need hardware virtualization support so that I can run XP mode. Where can I get the BIOS to flash in?
SOURCE: how to disable sata on sony vaio vgn nr 110e
For information on how to install XP (without using a floppy which has the SATA driver) on a SATA drive go to this WEB site :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
SOURCE: install xp on sony series nr
The BIOS doesn't care nor detect the installed OS and should only be upgraded if you are having BIOS issues.
The old adage "If it works don't try to fix it" certainly applies here.
SOURCE: forgotten bios password PCG-Z1RMP please help !!!!!!!!!!!!!!!
please remove the lithium cell from its place from 3 seconds then again put it in itsdefault place...........and start ur laptop...............and listen please dont try this without any one mechanic present ............only this is the soln.........this is very easy and not the matter of worry.................if u r helped then plz vote for me
SOURCE: Bios update for Sony Vaios SZ28GP upgrade to T7600
go to www.sony.com click on support and then drivers and then type in you model it will take you to the drivers page and it is concidered a driver
SOURCE: Can I upgrade Vaio laptop bios in Dos?
BIOS upgrades are USUALLY done in DOS. Most times, you need to boot from a floppy or CD that is specific for BIOS upgrade. Some BIOS upgrade software may be apllied through Windows, but this depends on your computer manufacturer.
BTW, if your computer is running ok, DO NOT MESS UP WITH THE BIOS. You may risk ruining your laptop.
IF IT IS NO BROKEN, DO NOT TRY TO FIX IT.
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Tally 7.2 is not longer supported. You might need to upgrade to the newest version.
The only other suggestion is to see if you can run in XP Mode. This will depend upon your computer requirements.
Running Windows XP Mode requires:
1. Windows 7 Professional, Enterprise, or Ultimate editions.
2. A computer capable of hardware virtualization. This means your computer has a central processing unit (CPU) with either Intel-VT or AMD-V virtualization features.
3. Virtualization features turned on in your computer's basic input/output system (BIOS).
To determine whether your computer's CPU is capable of hardware virtualization, go to the Windows XP Mode and Windows Virtual PC support website and download a utility that can check whether your Intel or AMD CPU is compatible.
http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
To find your brand of processor so you can download the appropriate utility, click the Start button , right-click Computer, and then click Properties. Under System, next to Processor, you can see what type of CPU you have.
Even if your CPU can run Windows XP Mode, you might also need to turn on virtualization settings in your computer's BIOS. Procedures vary depending on the BIOS manufacturer. For more information, see BIOS: frequently asked questions.
http://windows.microsoft.com/en-us/windows7/BIOS-frequently-asked-questions
For more information, please logon to:
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7#section_3
