Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Anonymous Posted on Oct 18, 2012
Amana AFD2535FES makes loud buzzing noise
Refrigerator and freezer are cooling properly. Several times a day the refrigerator makes loud buzzing noises. The compressor seems to run okay without making a loud buzzing noise There is a functioning ice maker, hooked up to a water line
John Tripp
Level 3:
  • Amana Master 4,656 Answers
  • Posted on Oct 19, 2012
John Tripp
Amana Master
Level 3:
Answers
4656
Questions
Helped
1679147
Points
14883
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
  • Anonymous Nov 08, 2012
    turns out the problem is the damper control at the back of the refrigerator. It makes a loud noise when opening/closing. I ordered a new one from repairclinic
  • John Tripp
    John Tripp Nov 08, 2012
    So this was the problem all along. Great that you have found the problem and will finally get this problem fixed. Thank You also for letting me know, John Tripp
3 Related Answers
Anonymous
  • Posted on Feb 21, 2011
SOURCE: Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Anonymous
  • 116 Answers
  • Posted on Mar 11, 2007
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Anonymous
  • 40 Answers
  • Posted on Jan 25, 2010
SOURCE: Amana ARB9059cs: compressor makes loud noise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Refrigerator not as cold as it should be, freezer too cold and has some frost
check the fan should be run in freezer & its air flow clear to refrigerator side,no blockage items or ice in its way oy of air flow
Refrigerator will not get cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
1helpful
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
3helpful
AMANA REFRIGERATOR MAKES A LOUD POP!
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
