There are several reasons for this and it would require some troubleshooting.
Here is some info on some of the troubleshooting procedure you can do. Or you could call a professional.
http://printertechsforum.com/forum/showthread.php?2306-HP-9050-Laser-Jet
SOURCE: HP optional 2000 sheet tray 4 problem.
Uninstall and then reinstall the drivers for this printer and then upgrade the firmware.....it will work....goodluck!
SOURCE: My hp laserjet 9050 show paper jam when the tray
(1) dose it work ok when you install paper.
(2) when it runs out of paper it dose not a sheet going through it so it gives that code .If its still works dont worry about it should be fine.
SOURCE: HP 9050 MFP keeps asking
You need to check the paper types you have assigned and the paper types that users are requesting. Print out a configuration page and make sure that Tray 4 shows as plain paper. If it does not then check all the stops. The 2000 sheet tray 4 units are noted for having the stops not engage and this causes the printer to think that tray 4 is custom media. You can also go into diagnostics and print a paper path test for each tray to ensure that all the trays are working.
SOURCE: We just hooked up our 9050 printer and it is not
Hello Sandra
The settings are automatically taken by the printer if you have made the changes required in the tray itself. And as far as the choosing the paper try, you need to make the settings in tray behavior in the printer. And choose the default paper size there.
