Hi The printer is actually not printing on one small section down the whole page, top to bottom.
SOURCE: Lexmark C510
try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
SOURCE: Lexmark X3350 printing
i just fixed this problem. first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges. follow that, it solved my problem.
SOURCE: Network printer cutting off page # and page name at top & bottom of page
hola que tal tengo un error con la impresora t642 me marca 241.10 me pueden ayudar
SOURCE: Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
SOURCE: Status idle + Test page onl shows top (reddish). Rest is blank.
Check that you're not out of "blue" and/or "black" ink.
For example, no "green" on the page means that the printer did not mix "yellow" and "blue".
Also, the "rest" of the test-page should be "black", if any black ink is available.
