TV and video inputs are correct. cable and channel settings are correct. Can hear TV, VCR and DVD but screen is black except it does show channel numbers and all the on screen displays as usual. Worked fine on day then no picture the next day when we turned it back on. Could it be a tuner problem ? The TV is old so I doubt if parts are available. JCV-3590S 35 inch Color Monitor/Receiver.
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
