Question about Whirlpool LER4634J Electric Dryer
LOUD NOISE WHILE DRYING
DRYER WHIRL: LER4634PQO. MAKES VERY LOUD NOISE, LOADEST WHEN PRESSING START. SOUNDS LIKE IT IS COMMING FROM THE BOTTOM RIGHT CORNER WHERE THE MOTOR IS CLOSEST TO. A FEW DAYS AGO I DRIED A FEW LOADS AND THE NOISE SOUNDED LIKE IT BEGAN TO DRAG. STOPPED THE DRYER THEN PRESSED START AND IT DID NOT RUN. NOW IT WILL RUN AGAIN BUT I AM NOT USING IT.
    Problem Solver:
  • 4 Answers
Remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Posted on Jan 03, 2009
6ya staff
SOURCE:
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
The timer makes a loud buzz sound and the dryer will not start
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 09, 2010 | Maytag PYE2300AY Electric Dryer
My whirl pool dryer is making a loud clicking noise
is it making a noise when going around if so something is stuck in the front or back bulk head making a clicking noisy as it is going around for example zipper or button of clothing
Apr 03, 2010 | Whirlpool LER4634J Electric Dryer
My Maytag LDE8600ADM Electric Dryer is making a loud knocking sound when it startes up and continues slightly quieter, but none the less knocking, while running and then the same loud knocking as at the...
Hi, Start the dryer and listen down in the lower front corner for the noise. This sounds to me like it could be the blower wheel loose on the front motor shaft.
Remove the 2 screws in the front panel and then remove the 4 screws holding the front bulkhead to the cabinet. You will be able to see the blower wheel and try to spin it by hand. If the blower spins free on the shaft, it will need replaced.
I hope this is helpfull to you. Please let me know if I can assist you further.
Thanks
Vic
Jul 26, 2009 | Dryers
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Very loud humming or whirling noise
it could be the motor starting to seize or the windings in the motor could be going bad either way it should be serviced
Jan 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Crosley CDE8000W Dryer has electric burning smell and shut down
it is most likely the belt. the squealing noise is because the motor is turning, but the belt is not. a replacement belt is not too expensive and it is fairly easy to replace. if you need directions how to replace it, let me know
Oct 27, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
226 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
