SOURCE: Slow Internet using Belkin Wireles G Plus MIMO
Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
Hope it help
SOURCE: Belkin Wireless Router
Just plug this router in and use the ethernet cable.
now use the (e) internet icon in your programs list. you will get an "cannot connect to internet" page or something like that.
in the TOP search area eg: address bar ...type in the ip address:192.168.2.1
and it should allow you acess to the site.
remember....you need your broadband account info..
YOU NEED TO GET THIS FAR TO SECURE YOUR WI-FI SYSTEM.
SOURCE: No wireless connection
You need to have an Internet Service Provider. You connect the router to a modem from the cable Service Provider or through the phone line for BT. Then you can connect wired or wirelessly to internet through the router.
If you describe your set up in detail and tell me the Internet Service Provider I may be able to help more....
SOURCE: I got a Belkin G+MIMO
Connect to Router using a Lan Cable.
Open the Advanced user interface page go to wireless tab and be sure radio signal is ON.
Check with my Tip all the step
Let me know if you nees any further info.
SOURCE: Bellkin G+ Mimo usb adapter - invisible
Use this tip as a check list.
Check if you set the correct SSID + Key and "connect if router is not broadcasting" set in your adapter configuration.
If you do not know Key you need to reset from Router.
If you missed SSID you can check on any PC when connected to WLAN and retrieve the name of NON BROADCASTED network
