Cars & Trucks Logo
Posted on Oct 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I only have sound on one side of my Miles Davis Tribute earphones. How can I fix this?
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Oct 17, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29023446
Points
266281
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
2002 Tribute water collecting on floor of cabin passenger side
SOUNDS LIKE YOUR A/C EVAPORATOR DRAIN IS PLUGGED. WHEN YOUR DRIVING THE EVAPORATOR WILL COLLECT CONDENSATION AND THEN DRIP OUT OF THE DRAIN. THE DRAIN IS LOCATED NEAR THE FIREWALL ON THE PASSENGER SIDE OF THE VEHICLE. SOMETIMES LEAVES OR MOLD/MILDEW WILL COLLECT THERE SIMPLY SHOVING A COAT HANGER END OR SCREWDRIVER WILL UN CLOG IT AND ALLOW THE WATER TO DRAIN.
Starting the 1st time the key is turned.
I had a similar problem with my 2001 Tribute. I changed the spark plugs and the problem went away. I had about 160K miles on the original spark plugs.
2answers
My o8 tribute leaking transmission fluid
fix the coolin lines going to the tansmission cooler its probably loose fitting going into the radiatior cooler 16mm wrench should fix u up 5/8"is the same as 16mm.
My tribute is getting hot and has a rattling/ tapping noise in the motor.I have checked the oil and water and both are fine. Is it possible that the timing belt needs replacing, and how often should this...
timing belts should be checked every 20,000 miles and replaced every 50,000 but sounds like you need a new thermostat and your valves are going bad
I have a 2006 Mazda Tribute. Can you tell me what the recommended time is between lube and oil changes. Is it 3000 miles or 5000. Thanks
It used to be every 3 months or 3,000 miles but some manufacturers are suggesting that 5,000 miles is ok. My view is that it does not hurt the motor having more oil changes. I continue to have them done every 3,000 miles myself even if my oil life indicator has not come on. Clean oil is very important to have a engine last for many miles. There are some full synthetic oils that can go for 5,000 or 7,000 miles beteween oil changes but cost alot more than the standard oil.
Stalling Tribute
sounds like a timing isue
have them do a sensor test
start the car on a hoist then tap the engine or if posable tap the timing sensor and also try shaking the wires running to the knock sensor and the tining sensor or distributor
Have a 06 Mazda Tribute S V6 4WD, with 35K miles on it. The problem is serious tire cupping. The dealer claims it is due to tires not being rotated. Funny thing, they were rotated every 6K miles per the...
cupping is caused by poorly acting shockabsorbers probably have leaking from the shock struts and may need replacement. sounds a bit early for wear at 50k
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
