The washing machine 1000 de luxe WM22 will go through washing cycles Ok but does not spin. It carries on to the end of the cycle but when on spin there is no movement. Have tried spin only with same results. Any ideas?
Yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Does the drum turn during the wash cycle?
When it comes to the spin cycle does it go through to the end without the drum turning?
It sounds like it could be the motor needs new carbon brushes.
Regards, Tom.
