My clock is on military time and I want it to read regular time. Need help with the mode to change it.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to factory installed systems not add
on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
SOURCE: Regular Time, Military Time
I believe it's a DIY. Find the owners manuel. You probably have to save it in standard time.
SOURCE: 2005 pontiac montana, clock reads in military time?
disconnect the battery or about five minutes in will reset the computer try that it should work
SOURCE: How do you reset the clock on the dashboard???
If you mean the clock that's part of the radio, you need to hold down the menu button for about 5 secs until the hour starts flashing then use the forward/reverse buttons below it to adjust it. Then press the menu button again for minutes and then again to send it back to normal mode.
Hope this helps. I found out by accident............
SOURCE: Can I change the clock in my 99 Beetle to standard
Yes. I believe you have to have the engine shut off. but with the power on hold the hour button until the time changes. you can change the temperature the same way but with the car running. in standard time 0 o- clock means midnight.
