Question about MSI K9N6PGM2-V Motherboard
K9n6pgm2-v pin out - MSI K9N6PGM2-V Motherboard
  • MSI Master
  • 5,660 Answers
MSI Support > K9N6PGM2-V motherboard > Main Support page,
http://www.msi.com/product/mb/K9N6PGM2-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down list click on - Manual
Now click on the blue -> M7309V1.2.zip
Click on the country name nearest yours.
A small window will come up on the right -
Opening M7309v1.2.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not left-click once in the small empty circle, to the left of Save File
Now go below in the window, and click on OK.
A small window will come up on the left. Allow the file to download all the way.
Now DOUBLE-click right on the file name.
In the next small window go to the left side, and click on -
Extract all files
At the bottom of the next three small windows, left-click on
Next, Next, and Finish.
In the last small window go to the file name next to the red Adobe PDF icon, and DOUBLE-click on it.
7309v1.2(G52-73091X3)
There is your motherboard manual in PDF file form.
( Plus + icon increases the view size when you click on it.
Minus - icon decreases the view size.
When I refer to a page number it will be for the PDF reader, and not the actual manual's page )
Go to Page 8.
Motherboard Layout
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
JFP1 is the Front Panel header.
JFP2 is an additional header. To be discussed after JFP1.
JFP1 is on the Right/Bottom corner. It is placed Vertically.
(Parallel to the right bottom edge of the motherboard)
Above it's left corner is JUSB2. (Front Panel USB header 2)
Above JUSB2 is the SATA2 connector. To the left of the SATA2 connector is the SATA1 connector.
To the left of the SATA1 connector is the CMOS battery.
The contact pins are arranged in two columns.
4 pins on the Left side, 5 pins on the Right side.
Go to Page 14. JFP1 pinout, and JFP2 pinout, is at the Bottom of the page.
JFP1:
Starting on the Bottom going towards the Top, Right side;
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going towards the Top, Left side'
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. (Probably 5 Volts positive, and used by the factory only)
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
IF the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
JFP2:
Below JFP1 is a header that is placed Horizontally. It is parallel to the Bottom edge of the motherboard. This header with 13 pins in it, is the JLPC1 header.
(Starting on left side at the Top row; 4 pins, no pin, 2 pins.
Starting on the left side at the Bottom row; 7 pins)
To the left of the JLPC1 header is the JFP2 header.
4 pins across the Top row, 3 pins across the Bottom row.
The top 4 pins across the top are for an internal speaker. Used to hear BIOS Beep Codes.
Starting on the Left side coming towards the Right, top row;
No indication of polarity.
Believe pin 2 is for the Positive wire, and pin 8 is for the Negative wire.
Starting on the Left side coming towards the Right, Bottom row:
Pins 1, 3, and 5.
These pins are ONLY used for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED.
(One example; Green Turbo, Yellow normal)
The rest of the pinouts are listed in the manual.
Have additional questions? Post in a Comment.
I also downloaded the manual.
Regards,
joecoolvette
Posted on Oct 16, 2012
6ya staff
SOURCE:
Driver of K9N6PGM2-V2
http://drivers.softpedia.com/get/GRAPHICS-BOARD/MSI/MSI-K9N6PGM2-V-NVIDIA-MCP61-chipset-dirver-1109.shtml
Here's your download link.
Also, please refrain from having to post the same question multiple times.
Jul 29, 2011 | Computers & Internet
MSI INSTALL DVD FOR K9N6PGM2
Hello - You can download all the system software available for that motherboard here.
Regards, Mikeywaf
Mar 07, 2011 | MSI K9N6PGM2-V Motherboard
Where to find k9n6pgm2-v audio driver download
http://www.msi.com/product/mb/K9N6PGM2-V.html#/?div=Driver
That is a link to the manufacturers driver download site, the driver is available for download right from that page.
Feb 28, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I NEED THE PIN OUT DIAGRAMS FOR K9N6PGM2-V MOTHERBOARD
Hi, here's the link for the manual, with the pinout diagrams:
http://global.msi.com.tw/index.php?func=downloadfile&dno=6801&type=manual
Please rate if you find this helpful :)
Mar 16, 2009 | Computers & Internet
MSI K9N6PGM2-V  Motherboard Logo
1,003 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
