Question about Tomtom GO 510 GPS Receiver
My gps will not recognise my sd card or turn on
Please help my gps just shows a green screen and for me to insert a sd card when i do insert a sd card it shows the sd card being taken out and a big red cross over the sd card please help thanks alan
  • 11 more comments
  • judy1242 Jan 01, 2008
    tomtom 510 will no recongnise sd care, just green screen with red X
  • janemarie Jan 26, 2008
    tomtom 510 will not recognise my sd card i just get a big red cross please help
  • Anonymous Feb 10, 2008
    Exactly dthe same as above. How do we fix?
  • aarons Mar 15, 2008
    Brand new item, just programmed home address and it was working for 5 minutes and I stopped, ran into grocery store and came out. Turned on car and gps and get same as above.
  • Anonymous May 31, 2008
    gps will not recognise my sd card I just get a big red cross and it shows the card going in and being taken out
  • robinallard May 31, 2008
    please help my gps just shows a green screen and for me to insert a sd card when i do insert a sd card it shows the sd card being taken out and a big red cross over the sd card please help
  • justinreiss Jul 08, 2008
    im having the same, first it lost all voices and then when i tried to update it my pc keeps shutting down ! is the unit fcuked ?
  • jgman2 Jul 24, 2008
    I have the same problem. I can't get to any screen or know how to clear my flash. Help! I am going on a trip on Friday and need my TOMTOM to work.
  • Anonymous May 11, 2010
    What is the Flash Utility?
  • Anonymous Mar 17, 2014
    can you use any gps sd card in any radio or does it have to be for ouku brand
  • Anonymous Mar 22, 2014
    Dear,
    I want to make a copy of my sd card but when i try to play the GPS it says a some point: problem with your licence.
    I have a good playing sd card but want to have a second one because i already had problem with my first card
    When trying tpo play the GPS it says problem with your licence: This is with a copy i want to make from the original SD card
  • Anonymous Mar 28, 2014
    need gps for navsure lost sd card
Try the clear flash utility. It worked for me. Martin
Posted on Sep 23, 2007
6ya staff
SOURCE:
Insignia gps only shows insert sd card, ?
when i tern on show pictuer insert sd card.i have sd card i inserted nothing happen?
Jan 12, 2013 | Insignia NSNAV01 GPS Receiver
Picture of sd card on screen. does nothing else!! tried reset no help!! inserted sd card still shows sd card wth arrow pointing in slot!!
You should try putting the SD card into a PC Card Reader and see if there is any data on the card. That normally happens when there is a bad connection or the card is blank.
Apr 13, 2011 | Insignia NSNAV01 GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Storage card formated but it still does not show up. please help
xda orbit can only hold 2gb sd memory stick and doesnt recognise the HD-micro-sd.
or..
try formating it in a PC or laptop.
Dec 11, 2009 | O2 Xda Orbit Smartphone
Magellan roadmate 1412 just stop working and displayed the following messange: "SD card has been removed. Program will restart. Please insert SD Card with map"
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
Oct 02, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Jun 02, 2009 | Magellan Roadmate 1200 Car GPS Receiver
TomTom one
Its more than likely that the data on your SD card has become corrupt or the card itself has become damaged / faulty. This can cause the tomtom to feeze on startup and doesn't even get past the loading process. You can "half" prove this by turning the tomtom ON without the SD card inserted. If you get the startup drums then a ' please insert SD card ' symbol on the screen , The card IS FAULTY . good luck. .................Hopefully , you backed up your SD card to your PC some time ago. If this is the case , you can just reload the files onto your SD card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE scandinavia
SD card no loger recognised...
It is a common problem after an update.
I personally had to contact tomtom & they talked me through formating the SD card & starting again.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Aug 26, 2007 | Tomtom One Europe v2 GPS Receiver
GPS Logo
639 people viewed this question
Top Tomtom GPS Experts
LP
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
