Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
Posted on Jan 01, 2009
Bosch PowerStar125 won't heat and I can't get one element to work
My Bosch AE125 has been working well for over a year then the other night it suddenly stopped. I went through the troubleshooting section of the guide and determined that one of the thermal cut-outs on top of the first of the three elements (one to far right facing them) would not reset. The light does not come on and I have no hot water. The transducer spins and there is no blockage in the inlet filter. The buttons in the thermal cut-outs atop the other two elements will reset and when I put the power back on the other two elements heat the water but the light does not come on and the first element does not work and the button on the thermal cut-out won't reset. I ordered a couple new thermal cut-outs and replaced the one that appeared to be bad but that has not changed anything and the problem persists with the exact same symptoms. Also, the new thermal cut-outs do not seem to reset like the ones do on the two elemets that work. The new thermal cut-out behaves just like the old one did and the button doesn't click and reset like the others do. Additionally even though I will get some hot water (even though the indicator light doesn't come on) when I first reset the cut-outs once I turn the water off they pop and I get no hot water at all unless I reset them again (only the middle and left thermal cut-outs will reset). Please help it is not fun heating water on the stove to wash myself and all the dishes every day.
  • yurya2 Jan 20, 2009
    Thanks for the answer. I believe you are correct. I did get a hold of Bosch and they told me the same thing. I have checked all the wires and connections and everything else is good. However, I don't have a multimeter and need to get one. Also, if it turns out that the copper canister unit is bad, what then? I need to do the Ohm out check but through a process of elimination that is likely the only thing left to be wrong. If the one element is bad does that mean the whole thing will have to be replaced? Or, is there a fix for that?
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Jan 19, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
21788
Points
42
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
  • Anonymous Jan 20, 2009
    Yes unfortunatley the heater was designed by controled energy. They make the heater. If you are the original purchaser it would be under warranty and bosch will send you a new heater. if your serial number begins with or before #62 then they dont want the old one back they will just send you a new heater. You will have to install it, or have a electrical tech or plumber install it for you.
    But the only way they will take care of this for you is to get the ohm readings on the elements. Then they will determin the unit is no good, and send you a new heater.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2557
Points
Hi did you ever get this resolved? I'm going through the same thing and looking for some advise. Thank you.
One element comes on the other does not come on only one side is heating
replace the bad one before the good one burns out fom having to work twice as hard.
We have power to the system but elements do not come on and heat water when you turn on water. there is 238 volts between all phases. System does not kick on when you turn water on
Control unit or flow transducer. If the transducer(impeller in the clear tube) is spinning freely with waterflow, then the circuit board needs to be replaced.
Failed Bosch AE125
Contact Bosch 800-283-3787, or service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Product has 10 year limited warranty against defects in workmanship, failed parts, failed heat exchanger for original homeowner with receipt. But does not cover neglect, failure to follow maintenance, installation etc. Pg 23 example manual
You generally have to pay for service call to verify installation, then send tankless into factory, or have service technician repair unit, at your expense minus cost of parts
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
To double check wiring:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Have an ae125 electric water htr. all power is at unit; elements ohm good and water is luke warm ; only pulling current on one circuit on each tank. power is present at board but does not seem to leave it ...
I don't know exactly how to solve your Bosch tankless problem, but there are resources for troubleshooting including contacting Bosch and reading manual.
You can buy 40 gallon tank-type electric water heater at Lowes for $207. Offer 10% less, and look for scratch and dent models with more markdown. Tank-type electric are easy to install and cheap to fix, cheap to maintain.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
My water heater just quit heating all at once
These heaters are an instaneous heater. Check the power supply at the switchboard. If okay the most obvious problem will be a blown/faulty element.
Not sure if my first try worked so will try again. Bosch PowerStar AE125 Tankless Water Heater. Quit heating water. Water pressure and flow is good. Thermal Cut-outs are good - (not tripped) (Power at...
The easiest thing to do would be to call Bosch and just ask for a new heater for free. The other option is to call Bosch and have them send you all new elements. If there is power, there should be heat of some kind.
2answers
Our second unit just failed and needs a new controller more money
The only Bosch tankless I have ever touched have been the 3 I have taken out and replaced with Rinnai. I think Bosch/Paloma/etc. have two problems:
1. They do not properly certify technicians before allowing them to install these units.
2. Their product is mediocre at best.
The biggest problem I've seen is that people don't vent them properly. The last one I pulled out had a combined vent length of 55'. 55 FEET! Absurd!
The units was condensing so much inside the vent that it washed out 2 gas control valves in ONE YEAR.
Buy Rinnai, buy Takagi, buy Noritz....maybe even a Navien (new player...time will tell)
Factory certified technicians, preferably equipped to do the gas & plumbing without having to sub it out.
Years of trouble-free hot water.
Good Luck.
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
