SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
SOURCE: Remote control code for Philips VCR & DVD player DVP3340V/17
If you have Dish Network and I suspect if you have Direct TV or a cable providers, you can use your remote for that service provider to find your VCR code. For the Dish you can look in the user's guide on pages 9 and 19 to see how to do a "Device Code Scan" and "Check Device Code".
To Scan: #1: Turn on the device you wish to scan for a code, #2 Press and hold down the button on your Dish remote for that device until all the buttons light up and the specific device button is flashing, #3 Press the blank power button, #4 press the up or down button until until your VCR tuns off, #5 Press the POUND ( # ) key to store the code number and #6 Press the blank power key to turn the device back on.
To Check the Device Code: #1 Press and hold down the device key until all buttons light up and the device button is flashing, next press the POUND ( # ) key TWICE ! The Mode button will flash to code number with a pause between each number, i.e. 5 flashes, pause 3 flaskes, pause one quick flash is 530. Write down this number and you are rady to go !
SOURCE: Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
SOURCE: panasonic quintrix tv code for lg v271 dvd/vcr combo remote
From another post, 0650 worked for me.
Panasonic TV 0051 0250 0650 0055 0162 0226 0338 0375 0637
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
