I purchased my LG BD-630 from the US a couple of years ago, and it is set for Region A/1 DVD's only. I see that this same model now for purchase is a Multi Region player. What I need to know is what is the code that I need to change my player from Region A/1 to Multi-Region?
SOURCE: Hack wanted to enable multi region
1) Go to the Preference page in the Setup menu
2) Press 1 3 8 9 3 1 on the keypad of the RC. I had to hold each number down for 2 or 3 seconds.
3) Options will be available to be selected. Select 0 using up/down on remote.
4) Player is now region free.
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
SOURCE: Laptop not recognizing drive...
sir
you should reinstall the drivers for your DVD ROM . It should be given to you when you have purchased it.
if not go here and download
SOURCE: Multiregion DVD region code for Samsung V6800
This is not promised to work but a known hack for your model of DVD player is...
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
People have reported a problem with the codes given however another was posted (57538) try that one to!!
Hope this works post back and let me know. Thank you for choosing Fixya!
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
http://download.cnet.com/dvd-genie/3000-2139_4-11629.html
Modify region code for software-based DVD players http://download.cnet.com/riodvd-region-free-player/3000-7970_4-10463982.html Play and watch your favorite movies in DVD, VCD, and SVCD formats. hope it helps
or free to try or buy
