SOURCE: how to calculate the Linear correlation coefficient
go to [2nd] [0] then select [diagnosticon] and click [ENTER] then it atomatically adds it to the LinReg(ax+b)
SOURCE: about 5 - 10 minutes into gaming, the screen will
No, cables RARELY go bad. More than likely it's the GPU on the motherboard. It's getting too hot.
You need to get some compressed air and blow out all the dust. It's best to do it outside ;)
Also give it about a minute or two before powering up again.
It also helps to use the PS3 in a vertical position, heat is your enemy!
Let me know what happens after following my suggestions.
--RescueTechLA
SOURCE: Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
SOURCE: You are given the following data.
OK, you convinced me to do your homework for you.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. To clear old data
B. Run the SetUpEditor command
C. Turn DiagnosticsOn option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. Enter the data
Press [STAT][1:Edit]
Type in the X values in L1 and the Y values in L2 (see picture 1)
To obtain the statistical results
Here is what you get (with you data).
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics. Some of the values your are looking for are among the result. NOW it is you mission to identify what you need (I chewed all the work for you).
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
Perform a Regression analysis
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. A linear regression it will be.
Here are your results.
The slope is a and the y-intercept is b. You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
Drawing the scatter plot and the raw data on the same screen.
Regardless of the curve of best fit, you can draw a scatter plot as follows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
And here is your two graphs: the raw data scatter plot and the line of best fit on the same screen
Now, it is up to you to accept this model or to try another model.
N
SOURCE: my r correlation doesn't show when I'm in linear regression?
You must turn the Diagnostics ON. Open the CATALOG of commands by pressing [2nd[0]. Press the key that has Letter D next to it. From that point in the catalog, scrool Down to get to DiagnosticsON. Highlight the command and press Enter. The calculator will echo the command in the Main screen. Press ENTER.
From now on the coefficient of determination ( the square of R) will be displayed along with other statistics.
