SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
SOURCE: I have a jbl 515
If you can watch the fuse kind of twitch. Most likely you have somthing shorted in your output amps. ( the ones on the heatsink underneath PCB) you'll probolly need a tech for this one to change out the transistors. Still under warranty?
