I bought a brand new memory card today, and the message I keep receiving is card setup, when I choose "Format", and select "yes", the message I immediately recieve is "Caution Erasing All". Then, when I select "yes", It displays "! Card Error". Please Help!!!!!!!!!!!
I was going to purchase a 1GB card but am now glad I didn't. If your card isn't bigger than 512MB, then have you tried to format it on a computer first? (Not sure you can do that, but might be worth a shot.)
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb card is not compatible.
The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
I've tried to send you a message 3 times so far today - not sure if this helps but a tech site suggested that the max capacity tested for the HP 318 was 16 MB - my card that I tried today was 8 gigabytes ..
I ordered a 16 MB card - hope it works. Good luck to both of us!
Mary
[email protected]
You need to look at your image storage settings. Press "Menu", "up/down" and "OK" to choose "Image Storage"; is it set to "auto" or "internal"?
If it's set to "Auto" then there's some reason that it's not recognising your memory card. You should format it. Press "Menu", "up/down" and "OK" to choose "Format" and then select the memory card.
If it's set to "Internal" then you need to set it to "Auto". Then it will use the memory card if it's inserted. (Take the card out to access the photos in Internal Memory.)
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the new card and do the format thing again.
Open messaging, go to Options, then Settings, the select "Other". In
other scroll to Memory in use. Here, click options and select change.
It will ask store messages to
•Phone memory
•Memory card
After selecting Memory card,
It will ask "Copy all messages to the new message memory?" Choose
Yes
Hi,The solution is to format the memory card or initialize the memory card.Note formatting the memory card will delete all the pictures or data stored.
Formatting memory card 1. Press the MENU button in any mode. 2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu. 3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Hi, You just need to format the memory card. And make sure that you are in memory card option for the picture storage when you take pictures. Formatting the memory cardThis function will format the memory card and will erase all files in memory including files that have been protected.Note: Once formatted all the images stored in the memory will be erased. This process is irreversible. Please download all images to the PC before formatting the card.1. Touch the icon (arrow down) function area until you see the “Format” option. 2.Touch the icon (memory card drawing/picture) function area to enter the Format menu. 3.Touch the icon (arrow left) function area to select OK/Cancel. 4.Press the Menu/OK button to confirm. 5.A Format message will appear on the LCD.FORMAT? YES NO6.Touch the icon (arrow right) or (Arrow left) function area to select Yes or No.
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards Before removing memory cards, turn the camera off and confirm that the power-on lamp is off. Open the battery-chamber/memory card slot cover and press the card in 1 to partially eject the card 2. The card can then be removed by hand. B Formatting Memory Cards If the message at right is displayed, the memory card must be formatted before use (A110). Note that formatting permanently deletes all pictures and other data on the memory card. Be sure to make copies of any pictures you wish to keep before formatting the memory card. Use the multi selector to choose Yes and press k. The confirmation dialog will be displayed. To start formatting, choose Format and press k. • Do not turn the camera off or open the battery-chamber/memory card slot cover until formatting is complete. • The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to format them using this camera (A110).
Refer Pg 110:
Format Memory/m Format Card
Use this option to format the internal memory or a memory card. Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu. Formatting a Memory Card
When the memory card is inserted in the camera, the Format card option appears in the setup menu.
I have the same problem. card says erase all, then card error. bought a second card and got the same response.
