IT SEEMS CHARGED BUT IT DOESN'T ALLOW TO ME DO ANUTHING ELSE
Hi escualo_s
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu. Then connect the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Please take time to rate me
Bud
SOURCE: I've a A1059 Ipod Model.
In many cases, the 20gb Classic and Photo models have problems with the Hard Drive. I have found over time, if you open the iPod, and remove the hard drive from the cable, remove the cable from the board and assemble it back together in reverse the problem will go away. The ipod cables tend to seat and don't make good contact.
to open your ipod, lay it on it's metal back, slide a guitar pick down the side between the metal case and the plastic front. slide it up and down the length of the ipod.do the same to the top and bottom. it should pop open. Up near the headphone jack and switch the is a cable attached, be careful not to open the ipod to fast, use a guitar pick to pry up the cable from the mother board and that will expose the inside. Now to remove the hard drive hold the black tab on the hard drive cable and pull the hard drive free straight back from the cable. To free the cable from the motherboard, lift the black lever clip up and open. now look at the cable end. If it is v shaped, straighten it and reinsert it in the motherboard and puc the black clip flat again. reassemble the ipod and give it a try.
SOURCE: my ipod is showing a caution sigh and it doesnt
Start by syncing your iPod with your computer. When you do this, the iPod management screen will appear. Midway down that screen there's a button that reads "Restore." Click the restore button. This begins the process of restoring the iPod to its factory settings. After you click the restore button, iTunes will ask you to confirm that you really want to do this. If your iPod content is backed up, go ahead. The iPod restore process includes iTunes downloading and installing iPod software and bug fixes. You will see a window that looks like this. Follow the onscreen instructions. On a Mac, you will be asked to enter your computer?s password. On Windows, the installation will just proceed. As iTunes restores the iPod, you will see a progress bar. After the restoration process has completed, iTunes will pop up a window letting you know that it?s done. Now you?ve got an empty, freshly formatted iPod. Now you can sync the iPod with your computer and download your iTunes library again.
SOURCE: Apple ipod 8gb model no. A1236 EMC No. 2174 seril
I would suggest agains posting your serial number on websites like FixYa.com
Sounds like a bad battery. You can get replacement batteries here http://www.ifixit.com/iPod-Parts/iPod-Nano
-=/ Daft Tech /=-
SOURCE: IPOD 4GB model no: A1236 EMC no. 2174
Where can i find driver for my IPOD 4GB model no: A1236 EMC no. 2174.
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
good luck
