Geoffery Mason Posted on Oct 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C-13 read error
Not readind disc
Eliezer Pennywhistler
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 236 Answers
  • Posted on Nov 12, 2012
Expert
Level 2:
Champion:
Cheetah:
Answers
236
Questions
0
Helped
61972
Points
247
You forgot to say if it is a C13 read error or a C13 REC error.
Your owner's manual suggests that it is a problem with a dirty and/or crappy disc. Try a different, cleaner one.
Jack Hughes
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2023
Jack Hughes
Contributor
Level 1:
Answers
Questions
0
Helped
590
Points
On the USB Function if you get ErrC13 on the LCD display it means the media is not supported
Gigaware compact disc 13-140 will not play CD. It trys to read then displays CD error
Could just need the lens cleaning. You can buy lens cleaning discs since the device is spinning the discs to read them.
1helpful
The DVD player reads disc error with every disc, even if the discs are cleaned.
If the DVD player is displaying disc error with all the discs, most probably it is a service issue..
Please use a cleaning disc and check if that helps.
8helpful
2answers
C:13:02
After having formatted the memory stick with the cardreader on my laptop which runs on winxp I tried to use the stick in my sony dsc-p5 but all I got was the C:13:01 error message. So I tried to format it again but eith FAT instead of FAT32 which is the regular format on winxp. Now the disc adapter which I use on my desctop to read the memory sticks worked again with the stickt, my camara still gave me the message of not being able to read the stick so I removed the stick, got into the setup mode, reinserted the stick and formatted it with the camara. This worked, I hope this can help you.
I have a Sony 626 6 disk CD player / stereo. I have cleaned the disk plaer multiple times, but it continues to skip. It is about 5 years old, is out of warrenty but otherwise works great! Any suggestions...
The board that reads the discs is giong out, it is not readind the discs properly. Repairing it is sometimes more expensive than buying a new one.You did get alot of use out of it, right? You got your monies worth...
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
In and out cd changer and error readind
Please explain what you are doing and what happens next. Since you've provided a generic problem the generic "reset everything solution" is unplug for 5 minutes plug back in and try it out. You might physically inspect the try and see if a foriegn object has been wedged some place it ought not.
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
9helpful
7helpful
2answers
Disc trouble
When i switch on my camcorder, it won't let me record. Error C13-02 is dispalyed on the screen. I have tried 2 different discs and have had no luck. Please help me repairs this.
 Grubhead
Grubhead
SmartAviator
SmartAviator
