Front load model # 417 48112701
Washer Not Filling: If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may
not align perfectly but don't worry, just get them to go back in the
hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
