D-Link DIR-685 Xtreme N Storage Router Logo
Posted on Oct 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D-link Dir-685 firmware update - D-Link DIR-685 Xtreme N Storage Router
Brian Sullivan
Level 3:
  • D-Link Master 27,725 Answers
  • Posted on Oct 15, 2012
Brian Sullivan
D-Link Master
Level 3:
Answers
27725
Questions
Helped
5664320
Points
79191
How to update D-link Dir-506L firmware
Just log in and go Tools and you will find Firmware upgrade. You can download the firmware and Manual from the given link.
DIR 506L Pocket Cloud Router
FIRMWIRE FOR DIR-615 REV M2
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of your router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
How do i update the firmware on my Dlink DIR-300 and also where can i find the latest firmware for the same..!!!
DLink.com, go there. Support, device name, read instructions, download firmware, flash device.
D-Link DIR 685 link drops regularly, I have firmware Ver 1 ,year2009
Try using a different channel. A higher one. Default settings often get interference from cordless land line phones (up to a mile away!!). Channel change usually resolves the issue.
Dlink dir 600 firmware corrupted
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Where can i find update firmware for my roughter
Go to THIS page: http://www.dlink.com/products/?pid=DIR-615
Click on SUPPORT RESOURCES near the upper right of the page.
Click on which REVISION your DIR-615 router is.
Then click on FIRMWARE.
Scroll the box down to the bottom and you will see the links to download your file.
1helpful
ASKING FOR FIRMWARE WHEN AM LONG IN
Seems like the Firmware of the router is corrupt and it needs to be updated.
You can download the DIR-600 Firmware (from D-Link Official Site, under Support Resources). Download the Firmware, read the instructions carefully and proceed. DO NOT TRY TO UPDATE THE FIRMWARE OVER WIRELESS CONNECTION. Do it over a wired connection.
The following video describes the procedure of updating firmware on DIR-600
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Is there an update for this wireless router? I purchased it last March. I am having trouble with my Ipad and the Apple technician wants me to make sure I have the latest driver.
Check the D-Link.com website for the latest firmware updates and driver updates for your Apple computer.
I've found that D-link offers frequent updates to the firmware, for instance, which may affect the performance of the router with your Apple product.
Good luck on updating your D-link DIR-615.
I need updates for dir 655 for windows 7
The only real update is a firmware upgrade. I'm having constant disconnect problems and the firmware upgrade only made it worse. Either wait for a better fix from D-Link or return for a different router. Updates and other information can be found here at D-Link's support page http://www.dlink.com/products/?pid=DIR-655&tab=3
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
