I got it from a friend since my old monitor burned out and I don't see it anywhere in the menu or on the buttons. The shortcuts on my desktop are farther away from the edge in the middle of the screen and I don't know how to remedy that problem. On my old CRT monitor it was in the menu but not on this one. Any suggestions?
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Testimonial: "very thanks...."
SOURCE: Syncmaster paower button blinking and no display
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW.
Oct 23, 2009
- This is how it went for me..I have a Samsung SYNCMASTER 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too.
- I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
SOURCE: Samsung SyncMaster 720N ...
OK, I've figured it out! There's something wrong with the control chip,
so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
SOURCE: my monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
