My computer come on afterSAYING VERFYING DMI POOL UPDATE SUCESS the goes blue screen
Bluescreen can be caused by a number of things a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail a bad driver loose or faulty lead or not having enough ram you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask the seller if they guarantee the compatability of the ram before making any purchase make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste if you can get a screen click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you computer came with a motherboard disk the drivers could be on it or you might have to download one or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
make sure all leads have a dust free secure connections
if you dont want to install more ram uninstall some unnecessary programs
hope it helps
SOURCE: acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
SOURCE: Bios update failed *flash*
You are in deep trouble
A problem with refreshing the Bios is that you can corrupt the old one and then the new one does not load leaving you stuck in limbo land
I would contact Acer support and hope that they offer a pre-programmed Bios chip to replace your corrupt one.
SOURCE: Disk read error-Verifying DMI Pool data... My
hello, Acer T180 comes with a SATA drive which are very reasonable priced these days. I think your system came with a 160GB hard drive (less than $50), you can probably get a 500GB for $50 bucks now.
here is a link to newegg for sata internal drive many of them free shiping for holiday season.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=internal+hard+drive+sata
you may come across few terms like "bare drive", "OEM", then there are regular ones. "bare drive" doens't come with wires(sata data & power connector), same with OEM- no wires, keep in mind OEM is genrally for resellers but i don't think anyone cares (:-) ).. since you are replacing the drive you have you can get by with any or these types. bare drive & OEM tend to be bit cheaper in price.
hope this helps
good Luck
regards,
Amar Sondhi
SOURCE: DMI Pool Data, Acer
You need a higher computer specification for Windows 7.
Acer Aspire T310 is design only for Windows XP Home/Professional and Windows 2000 according to Acer Support Page:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT310/AspireT310sp2.shtml
SOURCE: stuck at verifying dmi pool data
Try restarting in Safe Mode, press F8 at bootup and then either troubleshoot or do a system restore.
