Whirlpool LER4634J Electric Dryer Logo
Mary Coen Posted on Oct 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Senseon dryer control panel won't work
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Oct 16, 2012
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629115
Points
28464
Could you please explain the problem in depth for me? Not sure what you mean by the control panel not working. Is it getting power? Do you have lights on inside the dryer (if it is equipped with it)?
5 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Aug 12, 2011
SOURCE: My whirlpool ultimate care II electric dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Anonymous
  • 5911 Answers
  • Posted on Jun 30, 2009
SOURCE: Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Anonymous
  • 291 Answers
  • Posted on Nov 25, 2008
SOURCE: Whirlpool Dryer GEW9250PW0
the control panel is bad / it is also called a user interface
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 04, 2009
SOURCE: Whirlpool Senseon dryer GEW9868kq
The element is controlled by thermostats mounted inside the back of the dryer on the air exit box. There is also a contact on the motor that makes when the motor is running. Any of these could cause the problem. Try a different heat cycle, this may help narrow it down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 3361 Answers
  • Posted on Jul 24, 2010
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Whirlpool Senseon dryer model GEW9868KQ1 has E7 error code.
Question edited for clarity.
This is the technician repair sheet. Are you sure it is E7 and not E1?
https://www.applianceblog.com/mainforums/attachments/gew9868kq0-tech-sheet-pdf.17906/
I have done multiple searches for E7 and found nothing.
https://www.google.com/search?q=Whirlpool+Senseon+dryer+model+GEW9868KQ1+has+E7+error
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Whirlpool Senseon dryer stuck on one heat cycle
I found a work around that works for me. Press and hold wich cycle you would like, while still holding the button down choose which options you want such as time or heat ect. While still holding the button down press srart.
Whirlpool senseon dryer wont start, panel lights are on
Sounds like it had a short in the panel by the light flashing in the control boards some of the voltages are low & maybe wouldn't kick the breaker .If that's the case it may have damaged a part that wont let it start. Just guessing those boards are expensive that's why I don't like them .
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Whirlpool Dryer Model 6646AQ1 need schematics to diagnose why the dryer won't turn on. Electrical connections all checked and working. ???
Did you look inside the dryer? Full schematics & troubleshooting procedures are usually in either the back control panel or around the drum.
Gary
Senseon dryer stops running after only 5 min won't restart you can select the cycle but when you hit the start button it just beeps at me
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 • Dryers
In diagnostic mode, my Whirlpool senseon dryer displays 79 insstead of 88. What does this error code mean?
Idon't know the answer to this, but could you please tell me how to get into diagnostic mode on a senseon?
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
