Computers & Internet Logo
Kasie Dipietro Posted on Oct 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To restart an access point, where is the restart button?
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Oct 15, 2012
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1557103
Points
18452
Commonly with Access Point you can find the reset button on the back or bottom part of it , its a small hole that you need to press and hold for 10 seconds using a pen or paper clip to reset it back to default.
2helpful
5answers
I forgot my WEP password
On the back of the router there is a reset button or a pin-hole. Hold that in for 8 seconds and that will reset all your wifi settings to default. At that point there will be no password and it can be setup like new.
How to reset 1050AP
Severity: MODERATE Description:
The Red-M 1050AP Lan Access Point is a hardware device which provides a
LAN access point to Bluetooth devices. The device supports a web based
administration interface.
An issue has been discovered which could deny PPP users acces to the device.
Upon making a PPP connection to the Access Point, when prompted for PPP authentication credentials, an unusually long string of data supplied in the username field may initiate a denial of service condition. As a result, any new connection attempts will result in an 'Unable to establish a connection' error message.
A manual restart of the device may be required in order to regain normal functionality.
It is possible that this is the result of a boundary condition error, such as a buffer overflow. In this case, it is possible that exploitation could result in memory corruption, and possibly in the execution of arbitrary code. This has not, however, been confirmed. Normally, there is a small hole where you can use a small pin to poke the reset button.... Otherwise, just fumble around with it, and you probably find something :)
Affected Products:
  • Red-M 1050AP LAN access point
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
1helpful
2answers
I can not access the linksys access point, the 192.168.1.245 does not link.
the default address is 192.168.1.1. if you still can't access you can factory default by pressing and holding the reset button on the back for about 10 seconds. after it restarts the ip address will be 192.168.1.1 leave the username blank and the password will be admin.
I m unable to login my access point because off forget user name
there is one button(black and pin type) in backside or front side of the wirelss acccess point.just press 15 sec.it will automatically restart
No association with access point? was working
Try restarting your access point then restarting your computer. I have a wireless network and have to do this regularly. After I do, everthing works fine. As long as nothing happened to change your network settings on your computer, the restart should work.
I hope that this information was helpful and gets you started on the right track to solving your problem.
Brian
2answers
I have wireless internet how do i hook up my ps3
restore to factory settings and when you come to the network set up in the setup on restart choose the wireless option and if you have a WAP input it and you are good to go.
Hi,,, i have problem with hp j8131a access point i cant enable the new SSID,,, as i tick the enable button... the tick dissappear after i refresh the page.
After enabling button for ssid you have save settings .Save option is in system menu thensave settings then it automatic restart and take effect.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 • HP (J8131A)
2answers
Access Point AP2750 Problem
i would try updating the firmware on your router and access point. I had the same problem and did this to both and they are now working fine. Let me know how it goes.
Grand Canyon Tech
Grand Canyon Tech
