When turning on the hot water valve and watch the W.H. at the same time no clicks or sparks or FLAMES...
On a 1600H for god sakes give the Tech the S/N and the color code on the wiring at the flow sensor that starts the hydro sparker. They changed the thing in Mfr and there are 2 different parts. And also rebuild the water valve occasionally like every 3 years as Bosch recommends even if the cover which guides the pushrod is expensive. FYI we now usually buy a new WV as it\'s more reliable than rebuilding and you get all new parts. It\'s like $125 for a WV vs $59-71 for just the WV cover. Also never run these on very hard water fro a long time or you\'ll never descale em without Whitlam and a long wash out.
SOURCE: Bosch tankless GWH 1600 H NG won't always ignite
The clicking is a good sign. What are you trying that not working? How is the water flow-is it strong? 1) Turn the flow control button all the way to your left - this will increase the flow.
2) Pull the relief valve to simulate water flow and listen for clicking sound, and hopefully, main burner ignition. ( if installed in basement or kindly use bucket to catch water) The 1600 H NG will automatically shut off firing after 5sec of clicking.
3) How is the venting-use a household digital carbon monoxoide detector to measure any backspill from chimney.
4) Was the gas line disconnected in anyway after heater was installed? Air in the gas line will cause the igniter to click but no gas to fired the main burner.
Todate i have installed 11 Bosch Tankless Heaters -- 9(125 NG) Which is the same as 1600 Series
1(1600H NG) and 1(1600P NG)
Guess which one I having problem with- You guess it, however, the problem is their electrical wiring.
BE CAREFUL IN CALLNG BOSCH TECH. FOR SUPPORT. THE ARE GRILLING YOU TO FIND A LOOPHOLE WITH YOUR INSTALLATION TO RELIEF THEMSELF OF THEIR WARRANTY.
The manual says to hold a match near the pilot while the ignitor is
trying. It says that if the unit lights the pilot orifice may be dirty
or clogged. Then the manual says to check
the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
SOURCE: roblem with the Bosch 1600H-NG
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
