The LG900g works with microSD cards. Your 8GB card is actually a microSDHC card. While microSDHC cards will fit into the slot, they are electronically compatble and will not work in devices not specifically designed to work with the higher-capacity cards. You need to use microSD cards, 2GB and smaller.
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
SOURCE: Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
SOURCE: Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
SOURCE: i bought a 4 gig
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
SOURCE: My micro sd wont read on my computer or phone
click start control panel administration tools computer management device manager look through
all of your devices if you see a yellow question or exclamtion mark or a red X
a new driver will need to be installed right click update driver
if you can see your usb drive and its not working scroll to ports(com&lpt)right click update driver
http://download.cnet.com/o2micro-flash-memory-card/3000-18492_4-163841.html
if this fails to fix the problem your sd card might be faulty
hope this helps
