Router stopped working. unplugged it, now it won't power up.
SOURCE: How do i change my nat from type 3 to type 2 with
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
SOURCE: wont work my belkin usb
All wireless adapters use the same radio channels so your adapter will work with your router. (If that wasn't the case, it wouldn't be so easy to connect to networks with a laptop with built-in wireless.)
SOURCE: yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
SOURCE: belkin wireless
Your not the only person with a problem with this peticular Belkin item. Take it back and get something different you will NOT get this to install. I hate being the bearer of bad news...but this is the crappiest thing belkin has made yet!
SOURCE: hi am having connection
i bought this router earlier in the year. after trying to set it up and having problems i called belkin, who told me to call my internet supplier. virgin tried but couldnt help and told me ring belkin again. after trying everything they told me for about an hour and still no joy, i took it back to the shop.
