We have always left tray one empty until we need to use it for letterhead. Therefore the mass of our printing game from Tray two.
Now our printer does not pick from tray 2 at all. If we have paper in tray 1 2 and 3 the paper in tray 2 does not have paper pulled.
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
