Machine showed Ue code and still had water and washing in it. I could not open door so I turned off the power and waited then the door was able to be opened. Now when I turn the power back on it is set on longest cycle and no controls work. When power button is pressed, the machine turns on, but nothing works. Have to turn off main power to turn machine off. Any suggestions? Thanks
SOURCE: Samsung P1053S error code UE
The UE is an onbalanced load fault code.. Unplug the machine to clear the code.. leave it unplugged for about 10 mins and try to run it empty. If it persists you would be advised to contact a service technician. Bust of luck
SOURCE: Door switch on my samsung
I found a site that was not only free as it should be but has every jolly part under the sun and customer service as well. So naturally they instantly got my business.. Ray.
SOURCE: Samsung washing machine J1045 water over filling
This sounds more like the inlet valve is being supplied with constant power when its not supposed to be.This is normally due to the old valve spikeing the PCB & now you are getting constant power supply to the new valve.I think PCB needs to be changed as well.OE error was an after effect of the machine over filling.
I should have a "***** at work" sign. Somehow I activated the childlock! All good now , sorry to trouble anyone!!
