SOURCE: The microwave display shows "--SE--" I have not
SE error indicates a short in the keypad assembly. This will mean the the control panel or smart board will need to be replace.
Microwaves are not good do-it-yourself projects. Microwaves
are extremely dangerous to work on even while unplugged. Even
unplugged some components retain a lethal amount of voltage.
Here is a link for the website and contact technician: Sears Home Services .
Hope helps.
SOURCE: Microwave starts beeping, four times then displays SE
Sounds as if it may be getting hot look at the back and under the unit there will be a grid of sorts sometimes at the back and//or the bottom or side/s of the machine check to see if this is free of dust etc if not clean and try again remember microwaves can give a nasty bite//please switch off and unplug first..
SOURCE: Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
