I am surprised that this answer isn't found anywhere, including in the manual from Kaz. If yours is the same version as mine, and your lights aren't even lighting up on top, most likely your float may have gotten bound up with gunk (the float rises up when the pan is full enough of water, which enables the motor to run. It is held into place by a plastic bracket with two phillips head screws, and looks a bit like a plastic bottle with a narrow neck in a small rectangular shape (not open at top). Remove the screws and the bracket, and take out the float and clean it and the reservoir (in the base) it sits in. Reinstall, and the float should move freely. Problem solved!
SOURCE: tank is broken on Honeywell HCM-560 humidifier.
you type in on the internet. www.appliancefactory.com
in the search bar type in your model number. it might take a minute to load but you will have 3 pictures that come up. click on any of them and scroll down alittle until you see water tanks. you can order them there.. or if youdon't want to go that route you can always try local hardware stores to see if they have it as well.
SOURCE: humidifier drum Honeywell HE120 is not turning.
This happened with my humidifier as well. When the mineral deposits build up to the point where the drum binds, and is difficult to turn, the gears on the motor will strip. The clicking you hear are the ends of the stripped teeth of the motor gear rubbing up against the mating gears. Suggest you pull the motor - just remove the wire nuts from the control unit (replace wire nut over the exposed 24 Volt wire on each as you do this), then loosen and remove the nuts on the inside of the unit holding the motor. A number of manufacturers offer 'clock motors' than have a 1 rpm speed, and flat slot to receive the drum spindle. I used a Loeb motor which is commonly available in hardware stores, and had to insert a couple of small washers as standoffs, so the coupler was the right distance from the drum spindle. Reattach the controller wires, and you're done.
SOURCE: My Quietcare portable humidifier isn't
I was having the same issue. I noticed that when the main fan unit was removed, there was a small plastic piece that was sticking up from the base next to the filter, which has a female end on the fan unit. I played with this, and realized I could lift it up. Once I did this, I replaced the fan unit and it started working. I think this is the water level reader which, when all the way down, won't allow the fan to start since it thinks there is no water.
