I am not able to open it when I switch on it will automatacally switch off and cant received the calls.
Dear friend,
Since you are using complicated android device, I can't tel you the exact fix for your problem without handling your device or live conversation.
Your ppssible causes are:-
> viruses in your device.
> Low amount of free RAM,
> corrept mother bord.
> miss handeling with settings.
To fix your problem do the followings:-
> give a good virus check to both your device and memory card,
>boost your RAM by closing those application which are not in use, always keep RAM to 100mb free memory.
>if you still facing the problem then give a factory reset to your device.
> if still the problem exist, give your device to an authorised service centre they will change *********** board.
Regards,
Priyank Abhineet.
Dear friend,
Regards,
Priyank Abhineet.
SOURCE: my nokia 3110c mobile is
HI there,
This problem comes when phone memory is full, Please delete or move any pictures or videos you have saved in phone memory to memory card, or external source via connecting to PC.
Other possibility is that you have so many sms messages in your inbox, and normally when you switch on your cellphone, it will take around 15 to 20 minutes to load sms memory, and when you try to open inbox, It gives you error that memory not ready,
Solution:
Remove the sim card, and switch on the phone, wait until it fully initializes and takes phone memory intact, like when you are able to open sms messages,
For checking free space in phone,
Open Messages Go to options, > Memory status, it will show you the Total memory status of your phone, including free space, If you require your sms, take a backup on computer, via connecting your phone to Nokia PC Suite, and delete all unnecessary items in phone memory including SMS, in this phone there is a limitation of sms moving to memory card, so frree up space in phone memory and restart once, and you should be able to use phone features without any problem,
If you require more assistance, feel free to reply to this post,
Thanks for contacting FixYa!
Regards,
BA
May be your phone or phone memory card contains the virus or malware. So scan your memory card using the anti virus installed in your
machine.You can scan you memory card for antivirus using the Avira anti
virus.Please download the anti virus from :
http://www.avira.com/en/free-download-av...
Download the .exe file from the link.
Install
the software in your computer.Remove the memory card from the phone and
connect in your machine using the memory card reader and scan the card
for viruses or malwares.
