Doesnt stop filling with water.doesnt change cycle or spin.water leaks from cold water hose.
Water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Very simple fix, you open the top panel, then you can see the water inlet solenoid valve, which may not be insert deep to the bottom part after the machine move, just push the inlet valve down 1/2 cm, it will stop the water leak
My cold tap leaks water from top when I use machine fittings are good just moved to new premises could this have upset works
Part No: 47841-405 hoover washing machine
Same problem.Machine doesnt stop filling with water. Pressure stat is ok.Someone have to blow air into pressure stat vacuum hose ,all the time to stop taking water and start wash cycle. When I blow air down into air chamber I can hear water bubbling. Is it normal? Hoses are ok. How to clean air chamber please?
My washing takes forever to fill with cold water. Please advise how to fix it
fills with water but does not wash. it will only spin
fills with water but will not wash ..only spins
Hoover top load 500mb washer, fills with water and then dosent complete cycle of wash?
Dosent finish its cycle, fills with water and that's it?
Machine continues to run and doesnt stop at end of cycle
The cold water is supplied via a rainwater tank and is pumped into the laundry and there is plenty of pressure.
lg wft8501tp machine stops after one cycle. Water doesnt drain
when I turn on the washing machine the water will not turn off and flooded my living room. Its not the supply hoses. when I turn it off the water stops
My machine wont fill it is fitted with a partial aqua stop could i change it for a normal hose thanks
stopping in between cycle
The machine fills up normally but then the wash cycle won't start, it just clicks. But the spin cycle works normally
