KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
Jack Fullen Posted on Aug 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KitchenAid side by side refrigerator center wall is hot to the touch
Wife just opened refrig door, and came into contact with the seal on the centerline door, was very warm to the touch.. I checked the centerline wall, ran my hand along the outside of it and it was too hot to keep my finger on it.. checked the interior part of the wall, is cool on refrig side, cold on freezer side.. Ok, so what could be causing this overheat along the exterior part of this wall....
roeb
Level 3:
  • Master 819 Answers
  • Posted on Aug 06, 2017
roeb
Master
Level 3:
Answers
819
Questions
0
Helped
384663
Points
2343
Condenser coils dissipating heat.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Apr 06, 2008
SOURCE: kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Anonymous
  • 3 Answers
  • Posted on Feb 22, 2009
SOURCE: Center partition wall of refrigerator is hot !
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 01, 2009
SOURCE: Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Anonymous
  • 1136 Answers
  • Posted on Jun 19, 2009
SOURCE: I have a KitchenAid Superba Refrigerator, model
Hi, Sometines you can stretch the seal. T4ry and put a rolled up piece of paper towel and stick it behind the seal in the area that is not touching. If the seal is not touching in the corners, You might be able to twist the door back in shape. If the seal is open at the bottom, pull the top corner of the door toward you while holding the bottom corner against the refrigerator..
If neither of these ideas work, you will need to replace the seal.
Please let me know if I can assist you further.
Vic
Anonymous
  • 137 Answers
  • Posted on Nov 28, 2009
SOURCE: I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
2answers
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
The center pillar between the freezer and refrig is hot to the touch
That's entirely normal and nothing to worry about. It is a design feature that stops the door freezing shut. Check the condenser is clean and everything else is normal.
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
3helpful
3helpful
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
1helpful
Freezer is very cold and refrig is not
make sure the return air is open, that is a vent on the side wall of the refrigerator above the crispers on the center mullion. and check to see if the evaporator fan motor is running.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
