SOURCE: pusher won't come out
Hi,my name is patricia ,and i found a solution,first the black button .the black vise grip put it in the blade while the blade is still in turn the black vise grip to the left while still in the blade keep turning to the left and the blade will come off of the black button.the black button do not come off or up.When you put food in but smaller pieces in and have all your pieces near you so you can continue to drop in in the processer while running it and can slowly put the long tube in to keep food from splashing do it slowly .hope that help
SOURCE: stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
SOURCE: Juidelady jl500 juicer replacement parts
I also have a Juicelady, & need a part(s) HEre is a probable solution to your problem!
In the U.S.A. or Canada call 1-800-233-9054 to order the part. Or see if they have it in stock.They will ask for your address & phone number. Have your serial number ready-it should be on the bottom (or possibly the side) and you may need a magnifying glass to read it! It starts with the letters JL, and mine was JL500 (so look for that-but your may be a different model, I gave you mine so you have an idea of what to look for.)
Note: Anywhere else, or to check them out online:
The same warehouse is also at foxinternational.com if you'd rather see what they offer that way--but we got our call answered after waiting les than a minute. They even had the part we require but won't ship to Canada, so if your Canadian--call anyway, as it is a different part than we required,( the arms that brace the unit together.)
Hope this was helpful for you!
SOURCE: Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
SOURCE: rival juice extractor model 965
Trying to find a Rival Juice Extractor #965 Product Manual, Please help
Very helpful Noel -- thankfully you are wrong -- my husband rewired the juicer taking out the circuitboard and now it works fine
