Re: Have just had a Comcast cable box installed and now...
Enter the information and it will give you your codes. I can't do this as I don't know what remote you have. http://customer.comcast.com/Pages/HelpNFC.aspx?print=false&id=remotes
You should have gotten a folded manual with all of the codes though.
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
The real problem with the Comcast remote is that there is no other
brand, it's not like a Sony remote that's relabeled or anything.
Fortunately, Google helps again, and it turns out Comcast has a page
online about programming the Comcast remote control.
Comcast 3-in-1 remote control
To program the remote to work with your Sony TV, you need to take the
following steps:
Find the code or codes for your TV from Comcast's list [PDF]
Turn your TV on
On
the remote, press and release the TV key on the very top of the
remote.
Press and hold the Setup key, until the "TV" key
flashes twice, then release the "Setup" key.
Using the number
pad, enter in the first 4-digit code found next to your television brand
on the chart. If you do this correctly the "TV" key will flash twice.
Now it's programmed!
Now point the remote at your TV and press
the Power key. If the TV turns off, you're golden. If not, try
again with the next code on the list.
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
There is a code out there to try. The code would be 47. Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
