Question about RCA Lands Phones
How do I check L1 message waiting
2-line intercom speakerphone dect 6.0 cordless handset telephone answering system. I have checked for messages on L1 and "L1 message waiting still appears" the last message received was a text message. The blue light on the handset keeps flashing after I have checked for messages on L1
    New Friend:
I had the same issue on my RCA 25255re2 and worked with customer service at RCA. They had me hold down the delete button for 5 seconds, release the delete button, then press delete one more time. That cleared the phantom L1 message waiting issue we were having at my office
Posted on Apr 13, 2016
Anonymous
SOURCE:
ctess1
  • 3 Answers
SOURCE: To turn the blue light off
What worked for me was to call my phone and leave a voicemail. I then retrieved and deleted my voicemail which reset my handsets.
I hope this helps!
Posted on Jun 05, 2008
Lee
  • 393 Answers
SOURCE: digital phone/answering machine
The red blinking light is an 'event' light, it does not necessarily mean a message is waiting for you, it will also start to flash if you have a missed call.
click 'up' on the round button to show the missed calls list and it will stop flashing, at least it does on mine!
Posted on Apr 22, 2009
Muzahura Frank
  • 2069 Answers
SOURCE: I have 2 cordless and
when the handsets show searching, that indicates that they are having difficulty registering with the base. problem here could be the base itself. solution is to turn off base, unplug from wall socket, wait for about an hour, connect base and power it up. you may have to re-register the handsets for them to work again.
Regards
Posted on Jan 13, 2011
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: 2.4 GHz Corded/Cordless Answering System
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 19, 2011
Richard Van Brunt
  • 225 Answers
SOURCE: We have a GE Dect
Here is a link to download the manual in pdf format. The answer machine can be set to answer in 2, 3, 4, 5, or 6 rings. If your service provider(Frontier) forwards an unanswered call to the message service after 4 rings and your answer machine is set to answer after 6 rings, calls will never be answered by the answer machine. Frontier could be forwarding only busy calls to the message service but often busycalls and no answer calls are forwarded. You imply there has been a change in your service provider, the new company Frontier may not have kept your phone features the same, which may explain the difference. If you don't want your unanswered calls forwarded to the message service, call Frontier to change.
http://www.home-electronics.net/USER-GUIDES/28871_DOM_EN_CL_IB.pdf
Posted on Jan 27, 2011
How to change silent mode from on to off?
you have to go to settings., and from there, profiles section to change the mode silent to general model.
Nov 18, 2014 | Uniden DECT1560 DECT 6.0 Single-Line...
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
Dect phone manual
Standby mode is when the phone is not on a call, you're not dialing one, and you're not doing anything with the menus. It's standing by, waiting for you to call or for someone to call you.
Aug 09, 2014 | Panasonic KX-TG4022N DECT 6.0 Single-line...
DECT 6.0 Cordless Telephone Expansion Handset with Caller ID: I have the Uniden Dect 6.0 Telephone system with b...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do I set up a message on the answering machine
Turn to paage 8 of manual.
1) Press "message" - "mute" button, wait till message is finished.
2) press 8
3) wait for system to say "record greeting", then begin speaking.
4) when finished press 8.
5) to keep this greeting press "end".
6) To re-record go back to step 2
Nov 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
2,799 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
Ekse
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
