Gprs:unavailable
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
SOURCE: Sony Ericsson P1i phone does not detect network,
If the phone does not do so even in the location where there is good signal strength then the trans-receiver section had failed. If you have tools to remove , open and clean the terminals, of the main board, clean the suspected areas of any moisture , dry and set back. This is a highly embedded unit and so the chances of have it done is very little , The option to have it checked,confirmed and estimated is the best way than to tamper with limitations.
