Hot water only trickles and makes a humming noise. Cold wash works fine. Shortly before this, I heard a vibrating/water hammer type sound, again when used on hot only.
SOURCE: Whirlpool LSR8233EQ0 Hot water (only) trickles
you need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
SOURCE: cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
SOURCE: Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
If you turn off the water supply and switch the hot and cold hoses see if the problem the cold cycle is only trickling hot water. If the problem switches order a water inlet valve which is about $20.00. To replace the valve turn off the water and unplug the unit. Pull the unit out and remove the back panel. Disconnect the hoses from the valve and unplug the connecter. Replace the valve and plug in the connector reconnection all the hoses. Test the unit before closing it up.
