The Normal cycle doesn't pump water into the washer. It will run the whole cycle, spin the clothes, dispense detergent - but at the end of the cycle, the clothes are still bone dry. All other cycles work fine - pump water in, washes clothes. I'm assuming it can't be a clogged water line or bad pump, as all the other cycles work. Any ideas why just one cycle would stop pumping water?
SOURCE: Frigidaire front load washer wont high spin
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: Won't spin after wash cycle or rinse cycle
CHECK THE FOLLOWING---
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
SOURCE: Kenmore Front Load Washer, 417.44082400, will not
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
SOURCE: Affinity ATF7000 washer high speed spin not
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that
is activated at the end of the wash cycle for the machine to advance to the spin cycle.
This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies
that the auxiliary switch cannot be activated and the door lock and
switch assembly is faulty. Replaced the door lock and switch assembly
(part #131763202) to address the issue.
Disconnect power to the
machine. Open the washer door then look for the retaining hoop securing
the door seal around the lip of the door opening. Stretch the retainer
spring of the door seal retaining hoop then remove it.
Carefully
peel off part of the door seal from the lip of the door opening near the
door lock and switch assembly. Remove enough of the door seal to gain
access to the door lock and switch assembly.
Remove the screws
securing the door lock and switch assembly to the front panel. Once the
screws are removed, lift the door lock and switch assembly then pull it
away from the front panel.
Take the door lock and switch assembly
out of the machine. Disconnect the electrical connections then
connect it to the new door lock and switch assembly.
Put the new
door lock and switch assembly back into position in the front panel and
secure it with the securing screws.
Properly put the eased part
of the door seal back over the lip of the door opening then secure it
with the retaining hoop.
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Hello sisterw - If only the normal cycle is not lighting up on the keypad but all the other options do, then the washer may be experiencing a wiring failure. Try resetting the unit by unplugging it or flipping the breaker off. Wait approximately ten minutes. Restart the unit and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the control board as well.
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
