Stackable washer made a bang sound when washing a load. Opened it and found a piece of rubber by the front door broke off and now washer is leaking water.
See this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
SOURCE: thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
SOURCE: Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
SOURCE: My Frigidaire - Gallery Series - stackable
ABSOLUTELY! There is a plastic piece in the back that the center ball piece on the back of the drum spins in. Thats your bearing, replace it.
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Thank you so much for your help! We appreciate it!
