I have not used it for a while so I thought I would update the anti virus program. Tried via The menu - failed due to "network connection problems" I have no problem with t he wireless connection, it is working. Currently BIOS 1006 03/03/2009 program version Eee PC 1.1.0.14.
SOURCE: Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
SOURCE: asus EEE 901 super slow in the internet
clear temporary internet files and install tuneup utility increase RAM speed
SOURCE: Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
SOURCE: bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
There are two possiblities
One your old anti-virus setting is not remove from your PC.
Install **** cleaner (ccleaner) to get rid of the anti-viruses left over setting in the windows registry.
http://www.softpedia.com/progDownload/CC...
Two - a virus is preventing you from installing anti-virus
Use another clean PC to download Clamwin portable anti-virus and install it on a USB pen drive.
http://portableapps.com/apps/utilities/c...
Document on how to configure ClamWin
http://support.real-time.com/open-source...
Start Clamwin anti-virus and update the latest anti-virus definition files.
Select the tools menu bar, set the preferences to remove virus.
Start the infected PC in safe mode by pressing F8 during start up.
Run the Clamwin Anti-virus on the USB pen drive to scan the infected PC.
or
If you have tried all the various AV Removal Tools to look for expired/leftover remnants of other AVs, I'd suggest scanning your System for Malware.
Malware will often stop you downloading Security Products.
Download, install, update and scan with each of the two programs below to check for/remove Malware/spyware.
If necessary, do all the above work in Safe Mode with Networking.
To get into Safe Mode with Networking, tap F8 right at Power On / Startup, and use UP arrow key to get to Safe Mode with Networking from list of options, then hit ENTER.
Read all info below before starting:
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
hope this helps
