I need sony tv kv-21mf detail of factory setting
Visit the site named 'Electro-help' for
more details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 975 posts to different brand TVs now.
SOURCE: Sony Trinitron KV-1670 TV
go to web site www.serviceinfo.com it is available you will have to download.
SOURCE: setup codes for a sony kv-20fs12
i have sony kv 14 gmr1mk r2ks always shorted and the other 1 appear like a lightning in midle of screen.. kv 21gmr1mk when adjust the brigth and contras it shut down the picture and blinking..can u help me how to troubleshoot this problem? what remedy you sudgest..thank you...
SOURCE: dear sir i have a
Hello Sanam Khan,
Salam,
Do you want to reset service data of Sony KV-HA21M83A to factory default?
Let me know to help you out.
Allah hafiz.
SOURCE: To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
SOURCE: I need code for programing a universal TV remote control
You should be able to find the remote control code at this website. Good Luck→
http://www.tvcodes.com/index.html
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
